Temporary name shall reflect hostname
CelalD
When opening a file with an external editor, the filename is e.g.
C:\Users\<username>\AppData\Local\Temp\scp<random-nr>\path\to\the\file.sql
Request: this temporary file should include the server in it; e.g.
..Temp\scp<random-nr>\hostname\path\to\the\file.sql
Explanation: if opened two files with identical names from different servers (e.g. for comparing), it may irritating within the current behaviour. The hostname within the name would help to distinguish easily the opened files.
