Put local file into remote, but have local file selected from latest-modified folder.
Hello!
I have been having trouble figuring this out.
I use a custom python script to create backups of my .jar files I build, with the folder names being
I want to integrate semi-automatic file uploading into my workflow, but I do not know how to get the file
If this is not something that is supported yet, I'll suggest an implementation:
Placeholders (essentially local-to-line variables that are set using a - parameter)
Make placeholders accept input from
Thanks in advance.
dd-mm-yyyy-hh-mm-ss, where the first 'm's are month and the second are minutes.
NimoriaChar.jar from inside the latest-modified folder in the backups directory.
-latest (so that we can use the placeholder in the middle of a file path to dynamically select directories).
Thanks in advance.
