Nesting Includes files no longer automatically updating
BrianMount
Rochester, NY
We have our site set up with a # of nested folders. A file in one nested folder may be used in several different folders at a higher level. A change in a file in one folder has always been updated automatically in WinSCP until we did the most recent update. I suddenly find that I make a change in a lower-level file/folder and then have to open and save the higher-level folder before it updates in WinSCP so I can transfer. For the life of me, I changed nothing that I am aware of on our end but this is making what used to be a simple change and update now very, very time consuming, not to mention confusing trying to remember all of the upper-level files/folders impacted. Can anyone offer advice on what I need to change/update? I actually tried already rolling back to an earlier version of WinSCP with no success.
Brian at office@mybetterbenefits.org
Re: Nesting Includes files no longer automatically updating
Sorry, I do not understand.
What do you mean by "updated automatically in WinSCP"?
What do you mean by "open and save the higher-level folder"? How do you "save a folder"?
Maybe few screenshots may document you issue better.
BrianMount
Martin,
Apologies as it was not an issue with WinSCP but with the older .html publishing progam I was using to update the website.
