A Feature to Restrict Access to Remote Disks
namsic
I use a remote disk setup for quick access to my NAS folders. Since the NAS is on a different network from my computer, I need to activate a VPN to access the disk. This setup works quite well, as I only need to activate the VPN when I need to access the NAS, which is not a major issue.
However, it seems that WinSCP attempts to access these local disks when launching and at regular intervals. When the program starts—or even quite frequently afterward—it becomes unresponsive. I initially thought this might be due to my settings, so I updated to the latest version, 6.5.1, but the issue persists.
After researching a bit, I suspected this issue is caused by the program trying to access NAS disks that are not available. Indeed, when I activated the VPN and made the disks accessible, the problem disappeared.
I understand this issue could arise if I had attempted to access the remote disks through WinSCP while the VPN was off. However, I did not attempt to access those disks. I only had a single tab open connected to my Downloads - Documents folder, yet the issue still occurred.
Therefore, I’d like to suggest implementing one of the following options:
  • A feature that allows users to prevent WinSCP from trying to read specific disks.
  • An improvement that prevents the program from becoming unresponsive when it attempts to access inaccessible disks.
  • An alternative improvement where the program only hangs once when it initially encounters an inaccessible disk, but avoids repeated access attempts unless explicitly requested by the user. (I assume option 2 may be harder to implement, so option 3 might be an acceptable compromise.)
Re: A Feature to Restrict Access to Remote Disks
namsic
Here are the log files.
There are a total of three files, and freezing occurred in all three cases.
The first file(WinSCP09DCtrace.log) is quite large because it took some time for the issue to occur, and I ended up doing unnecessary actions until the freeze happened.
So I created a second file(WinSCP30F8trace.log), but I didn’t check the exact time when the bug occurred.
In the third file(WinSCP1214trace.log), I confirmed that the freezing happened roughly between 15:09:08 and 15:09:28.
  • debug_log.zip (2.95 MB, Private file)
namsic
I tested it with the development version, and the issue of the program freezing is gone. That's great!
Thanks for your help and feedback! Let me know if you have any problems.
