Error status code 1 (files not copying over)
Browndon.Bokanga
WinSCP version - 6.5.1(Build16211 20250505)
WinSCP Sync does not sync file 5020 and
. 2025-06-26 17:16:08.924 Collecting synchronization list for local directory '\\SS24\dataintegrations$\Folder1\DropFolder\5002' and remote directory '/DataLoader/Contact/5002', mode = Remote, params = 0x2 (NoConfirmation), file mask = ''
. 2025-06-26 17:16:08.927 Local file '\\SS24\dataintegrations$\Folder1\DropFolder\5002\.' [2025-06-26T14:38:19.955Z] [0] excluded from synchronization
. 2025-06-26 17:16:08.927 Local file '\\SS24\dataintegrations$\Folder1\DropFolder\5002\..' [2025-06-26T14:38:19.955Z] [0] excluded from synchronization
. 2025-06-26 17:16:08.927 Local file '\\SS24\dataintegrations$\Folder1\DropFolder\5002\5002.CSV' [2025-06-26T14:51:35.429Z] [9196] included to synchronization
. 2025-06-26 17:16:08.928 Listing directory "/DataLoader/Contact/5002".
> 2025-06-26 17:16:08.928 Type: SSH_FXP_OPENDIR, Size: 33, Number: 1291
< 2025-06-26 17:16:08.937 Type: SSH_FXP_STATUS, Size: 19, Number: 1028
. 2025-06-26 17:16:08.937 Discarding reserved response
< 2025-06-26 17:16:08.975 Type: SSH_FXP_HANDLE, Size: 13, Number: 1291
> 2025-06-26 17:16:08.975 Type: SSH_FXP_READDIR, Size: 13, Number: 1548
< 2025-06-26 17:16:08.986 Type: SSH_FXP_NAME, Size: 235, Number: 1548
> 2025-06-26 17:16:08.986 Type: SSH_FXP_READDIR, Size: 13, Number: 1804
< 2025-06-26 17:16:08.995 Type: SSH_FXP_STATUS, Size: 34, Number: 1804
< 2025-06-26 17:16:08.995 Status code: 1
> 2025-06-26 17:16:08.995 Type: SSH_FXP_CLOSE, Size: 13, Number: 2052
. 2025-06-26 17:16:08.995 .;d;0;2025-06-26T16:16:08.000Z;4;"sftp-2b3ed5cb019c@apiconnector.com" [0];"users" [0];rwx------;0
. 2025-06-26 17:16:08.995 ..;d;0;2025-06-26T16:16:08.000Z;4;"sftp-2b3ed5cb019c@apiconnector.com" [0];"users" [0];rwx------;0
. 2025-06-26 17:16:08.995 Local file '\\SS24\dataintegrations$\Folder1\DropFolder\5002\5002.CSV' [2025-06-26T14:51:35.429Z] [9196] is new
. 2025-06-26 17:16:08.995 Collecting synchronization list for local directory '\\SS24\dataintegrations$\Folder 1\DropFolder\5020' and remote directory '/DataLoader/Contact/5020', mode = Remote, params = 0x2 (NoConfirmation), file mask = ''
. 2025-06-26 17:16:09.001 Local file '\\SS24\dataintegrations$\Folder1\DropFolder\5020\.' [2025-06-26T16:15:11.749Z] [0] excluded from synchronization
. 2025-06-26 17:16:09.001 Local file '\\SS24\dataintegrations$\Folder1\DropFolder\5020\..' [2025-06-26T16:15:11.749Z] [0] excluded from synchronization
. 2025-06-26 17:16:09.001 Local file '\\SS24\dataintegrations$\Folder1\DropFolder\5020\5020.CSV' [2025-06-26T16:15:10.641Z] [13986] included to synchronization
. 2025-06-26 17:16:09.001 Listing directory "/DataLoader/Contact/5020".
> 2025-06-26 17:16:09.001 Type: SSH_FXP_OPENDIR, Size: 33, Number: 2315
< 2025-06-26 17:16:09.011 Type: SSH_FXP_STATUS, Size: 19, Number: 2052
. 2025-06-26 17:16:09.012 Discarding reserved response
< 2025-06-26 17:16:09.046 Type: SSH_FXP_HANDLE, Size: 13, Number: 2315
> 2025-06-26 17:16:09.046 Type: SSH_FXP_READDIR, Size: 13, Number: 2572
< 2025-06-26 17:16:09.084 Type: SSH_FXP_NAME, Size: 361, Number: 2572
> 2025-06-26 17:16:09.084 Type: SSH_FXP_READDIR, Size: 13, Number: 2828
< 2025-06-26 17:16:09.094 Type: SSH_FXP_STATUS, Size: 34, Number: 2828
< 2025-06-26 17:16:09.095 Status code: 1
> 2025-06-26 17:16:09.095 Type: SSH_FXP_CLOSE, Size: 13, Number: 3076
. 2025-06-26 17:16:09.095 .;d;0;2025-06-26T16:16:09.000Z;4;"sftp-2b3ed5cb019c@apiconnector.com" [0];"users" [0];rwx------;0
. 2025-06-26 17:16:09.095 ..;d;0;2025-06-26T16:16:09.000Z;4;"sftp-2b3ed5cb019c@apiconnector.com" [0];"users" [0];rwx------;0
. 2025-06-26 17:16:09.095 5020.csv;-;14582;2025-06-26T16:16:09.000Z;4;"sftp-2b3ed5cb019c@apiconnector.com" [0];"users" [0];rw-------;0
. 2025-06-26 17:16:09.103 Remote file '/DataLoader/Contact/5020/5020.csv' [2025-06-26T16:16:09.000Z] [14582] is modified comparing to local file '\\SS24\dataintegrations$\Folder1\DropFolder\5020\5020.CSV' [2025-06-26T16:15:10.641Z] [13986]
WinSCP does not copy file 5020.csv (file was in WinSCP but did not sync with newer version of file)
5002 copied to WinSCP
This is the current script
synchronize remote -resumesupport="off" "\\folderW\dataintegrations$\folder1\DropFolder\" /DataLoader/Contact/
. 2025-06-26 17:16:18.598 Synchronizing local directory '\\SS24\dataintegrations$\Folder1\DropFolder\5002\' with remote directory '/DataLoader/Contact/5002/', params = 0x2 (NoConfirmation)
. 2025-06-26 17:16:18.598 Copying 1 files/directories to remote directory "/DataLoader/Contact/5002/" - total size: 9,196
. 2025-06-26 17:16:18.599 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 0001; Resume: N (102400); CalcS: No; Mask: *.*
. 2025-06-26 17:16:18.599 TM: B; ClAr: No; RemEOF: No; RemBOM: No; CPS: 0; NewerOnly: No; EncryptNewFiles: Yes; ExcludeHiddenFiles: No; ExcludeEmptyDirectories: No; InclM: ; ResumeL: 0
. 2025-06-26 17:16:18.599 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; *.js; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2025-06-26 17:16:18.600 File: '\\SS24\dataintegrations$\Folder1\DropFolder\5002\5002.CSV' [2025-06-26T14:51:35.429Z] [9196]
< 2025-06-26 17:16:18.639 Script: Local '\\SS24\dataintegrations$\Folder1\DropFolder\5002' => Remote '/DataLoader/Contact/5002'
. 2025-06-26 17:16:18.644 Copying "\\SS24\dataintegrations$\Folder1\DropFolder\5002\5002.CSV" to remote directory started.
. 2025-06-26 17:16:18.644 Binary transfer mode selected.
. 2025-06-26 17:16:18.644 Opening remote file.
> 2025-06-26 17:16:18.644 Type: SSH_FXP_OPEN, Size: 58, Number: 86275
< 2025-06-26 17:16:18.766 Type: SSH_FXP_HANDLE, Size: 13, Number: 86275
> 2025-06-26 17:16:18.767 Type: SSH_FXP_WRITE, Size: 9221, Number: 86790
> 2025-06-26 17:16:18.768 Type: SSH_FXP_CLOSE, Size: 13, Number: 87044
> 2025-06-26 17:16:18.768 Type: SSH_FXP_SETSTAT, Size: 54, Number: 86537
< 2025-06-26 17:16:18.781 Type: SSH_FXP_STATUS, Size: 19, Number: 86790
< 2025-06-26 17:16:18.781 Status code: 0
< 2025-06-26 17:16:18.799 Type: SSH_FXP_STATUS, Size: 19, Number: 87044
< 2025-06-26 17:16:18.799 Status code: 0
. 2025-06-26 17:16:18.801 Preserving timestamp [2025-06-26T14:51:35.000Z]
< 2025-06-26 17:16:18.844 Type: SSH_FXP_STATUS, Size: 19, Number: 86537
< 2025-06-26 17:16:18.845 Status code: 0
. 2025-06-26 17:16:18.845 Transfer done: '\\SS24\dataintegrations$\Folder1\DropFolder\5002\5002.CSV' => '/DataLoader/Contact/5002/5002.CSV' [9196]
. 2025-06-26 17:16:18.845 Copying finished: Transferred: 31,430, Elapsed: 0:00:05, CPS: 5,868/s
. 2025-06-26 17:16:18.845 Synchronizing local directory '\\SS24\dataintegrations$\Folder1\DropFolder\5021\' with remote directory '/DataLoader/Contact/5021/', params = 0x2 (NoConfirmation)
. 2025-06-26 17:16:18.845 Copying 1 files/directories to remote directory "/DataLoader/Contact/5021/" - total size: 3,070
. 2025-06-26 17:16:18.845 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 0001; Resume: N (102400); CalcS: No; Mask: *.*
. 2025-06-26 17:16:18.845 TM: B; ClAr: No; RemEOF: No; RemBOM: No; CPS: 0; NewerOnly: No; EncryptNewFiles: Yes; ExcludeHiddenFiles: No; ExcludeEmptyDirectories: No; InclM: ; ResumeL: 0
. 2025-06-26 17:16:18.845 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; *.js; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
