Resumed file after connection loss is overwritten
moffa13
BE
I was transferring a 128Go file previously resumed.
I then lost connection, WinSCP tried to connect me multiple times for around 20min until I gained connection again but instead of resuming the file, it started over again from 0.
WinScp 6.5.1 16311
Windows 11 24H2
FTP explicit TLS/SSL
Interface GUI commander
Re: Resumed file after connection loss is overwritten
