Copy instead of preferred drop effect
nleontiev
Russia
WinSCP (6.5.3 Build 16364) performs copy operation instead of move when pasting from clipboard which contains Preferred DropEffect move (2).
Clipboard contents:
Format ID         : 15
Format Name       : CF_HDROP
Handle Type       : Memory
Index             : 1
14 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
01 00 00 00 43 00 3A 00 5C 00 74 00 65 00 73 00
74 00 2E 00 74 00 78 00 74 00 00 00 00 00
Format ID         : 49349
Format Name       : Preferred DropEffect
Index             : 2
02 00 00 00
HDROP item: C:\test.txt
SHFileOperation call with wFunc=2 (FO_COPY):
#   Time of Day   Thread   Module   API   Return Value
6   7:46:33.421 AM   1   WinSCP.exe   SHFileOperationW ( 0x00733a30 )   0
#   Type   Name   Pre-Call Value   Post-Call Value
1   LPSHFILEOPSTRUCT   lpFileOp   0x00733a30   0x00733a30
   SHFILEOPSTRUCT      { hwnd = 0x001b0a76, wFunc = 2, pFrom = 0x06c40d8c  ...}   { hwnd = 0x001b0a76, wFunc = 2, pFrom = 0x06c40d8c  ...}
   HWND   hwnd   0x001b0a76   0x001b0a76
   UINT   wFunc   2   2
   LPCTSTR   pFrom   0x06c40d8c "C:\test.txt"   0x06c40d8c "C:\test.txt"
   LPCTSTR   pTo   0x04fc83cc "D:\"   0x04fc83cc "D:\"
   FILEOP_FLAGS   fFlags   592   592
   BOOL   fAnyOperationsAborted   0   0
   LPVOID   hNameMappings   0x00000000   0x00000000
   LPCTSTR   lpszProgressTitle   0x00000000   0x00000000
   int   Return      0
Reply with quote E-mail
Re: Copy instead of preferred drop effect
Is this about local or remote files?
WinSCP does not support "cutting" remote files. Hence it ignores "preferred drop effect" as it supports "copying" only anyway.
