Feature request: per-session file sorting settings
adroman
I am using WinSCP 6.x and I noticed that file sorting (by name, size, modification time, etc.) is applied globally across all sessions. This means that if I change sorting for one saved session, the same sorting order is applied to all other connections as well.
For my workflow, it would be very useful if sorting preferences could be saved individually per session, so that each stored connection remembers its own preferred sorting method.
Could you please let me know if this feature is planned for future versions, or if there is a workaround to achieve session-specific sorting?
Thank you in advance for your help and for your great software.
Re: Feature request: per-session file sorting settings
No it's not possible.
It might be possible to save sorting with a workspace.
