Wrong formatting of the text using both internal and external readers
asap
Hello, I am facing the issue with both internal and external (Windows Notepad) readers. On my old computer with Windows 7 it works fine. But on my other computer with Windows 10 there is wrong formatting of the text. I can see only strange symbols.
I tried several settings but nothing helped. Can anybody help what to do to see the text correctly?
I use the latest version 6.5.3.
Thank you.
Re: Wrong formatting of the text using both internal and external readers
What encoding do your files use?
Do you possibly have different Windows legacy encoding configured on those machines?
Control Panel > Clock and Region > Region > Administrative > Language for non-Unicode programs
If this does not help, please post an example file.
