Auto writes data buffered in memory out to disk before logout
huangsijun17
I have some embedded devices connected via SFTP. I need to power off the device after copying files via WinSCP. However, powering off the device directly will result in some data loss, so I need to run the sync command to write the copied files to the disk. Can I automatically execute the command to write the files to the disk when WinSCP disconnects?
Reply with quote E-mail
Re: Auto writes data buffered in memory out to disk before logout
You mean to execute some proprietary sync command over the FTP protocol/connection?
That's even more confusing for me – as there are no textual commands in the SFTP protocol.
Perhaps you mean sync shell command?
