Synchronizing folders by timestamp issue
hebo209@126.com
Hello, Administrator.
I currently have the following requirement:
I need to synchronize a local Windows directory to a remote FTP server, only syncing files and folders whose creation time is later than 2025-09-27.
I'm using a command similar to this:
synchronize remote -filemask="*>=2025-09-27" "D:\test02" "/MES/test/test002"
In my local directory, there are both files and folders created before and after 2025-09-27.
When I run this command, I observe that:
Files and folders created after 2025-09-27 are synchronized correctly.
However, folders created before 2025-09-27 are also being synchronized—but only as empty directories (the old files themselves are not transferred).
This behavior deviates from my requirement. I only want to sync files and folders created after 2025-09-27, including their contents, and skip any folders that don’t contain qualifying items.
How should I adjust my command to achieve this?
Below is the structure of my local directory:
Mode LastWriteTime Length Name
d----- 2025/9/11 16:35 t
d----- 2025/9/28 17:21 test
-a---- 2025/9/28 16:43 17 123.txt
-a---- 2025/8/24 15:44 30 cmd_start_for.ini
-a---- 2024/5/25 8:22 12288 DumpStack.log
-a---- 2024/8/19 15:32 2664 https_sunlogin.oray.com.localstorage
