WebDAV - HTTP Basic Auth
franc
franc avatar
Hallo
I have a WebDAV Login at a Hetzner Storage Box where I can login successfully with (actual) WinSCP with WebDAV. In the (debug level 2) log I read:
. 2025-10-07 14:54:39.512 --------------------------------------------------------------------------
. 2025-10-07 14:54:39.513 WinSCP Version 6.5.3 (Build 16364 2025-07-16) (OS 10.0.22631 – Windows 11 Enterprise)
. 2025-10-07 14:54:39.514 Configuration: C:\Program Files (x86)\WinSCP\WinSCP.ini
. 2025-10-07 14:54:39.514 Log level: Debug 2
. 2025-10-07 14:54:39.514 Local account: FRANC-COMP\f
. 2025-10-07 14:54:39.514 Working directory: C:\Program Files (x86)\WinSCP
. 2025-10-07 14:54:39.514 Process ID: 4624
. 2025-10-07 14:54:39.522 Ancestor processes: explorer, ...
. 2025-10-07 14:54:39.522 Command-line: "C:\Program Files (x86)\WinSCP\WinSCP.exe"
. 2025-10-07 14:54:39.522 Time zone: Current: GMT+2, Standard: GMT+1 (Mitteleuropäische Zeit), DST: GMT+2 (Mitteleuropäische Sommerzeit), DST Start: 30.03.2025, DST End: 26.10.2025
. 2025-10-07 14:54:39.522 Login time: Dienstag, 7. Oktober 2025 14:54:39
. 2025-10-07 14:54:39.522 --------------------------------------------------------------------------
. 2025-10-07 14:54:39.522 Session name: Hetzner-CH-WebDAV (Site)
. 2025-10-07 14:54:39.522 Host name: u123456.your-storagebox.de (Port: 443)
. 2025-10-07 14:54:39.522 User name: u123456 (Password: Yes, Key file: No, Passphrase: No)
. 2025-10-07 14:54:39.522 Transfer Protocol: WebDAV
. 2025-10-07 14:54:39.522 Proxy: None
. 2025-10-07 14:54:39.522 HTTPS: Yes [Client certificate: No]
. 2025-10-07 14:54:39.522 WebDAV: Tolerate non-encoded: No
. 2025-10-07 14:54:39.522 TLS/SSL versions: TLSv1.2-TLSv1.3
. 2025-10-07 14:54:39.522 Local directory: C:\Users\f\Desktop, Remote directory: /, Update: Yes, Cache: Yes
. 2025-10-07 14:54:39.522 Cache directory changes: Yes, Permanent: Yes
. 2025-10-07 14:54:39.522 Recycle bin: Delete to: No, Overwritten to: No, Bin path:
. 2025-10-07 14:54:39.522 DST mode: Unix
. 2025-10-07 14:54:39.522 Compression: No
. 2025-10-07 14:54:39.575 HTTP session to https://u123456.your-storagebox.de:443 begins.
. 2025-10-07 14:54:39.576 ssl: SNI enabled by default.
. 2025-10-07 14:54:39.576 auth: Create for WWW-Authenticate
. 2025-10-07 14:54:39.576 Running pre_send hooks
. 2025-10-07 14:54:39.576 Sending request headers:
. 2025-10-07 14:54:39.576 OPTIONS / HTTP/1.1
. 2025-10-07 14:54:39.576 User-Agent: WinSCP/6.5.3 neon/0.34.2
. 2025-10-07 14:54:39.576 Keep-Alive:
. 2025-10-07 14:54:39.576 Connection: TE, Keep-Alive
. 2025-10-07 14:54:39.576 TE: trailers
. 2025-10-07 14:54:39.576 Host: u123456.your-storagebox.de
. 2025-10-07 14:54:39.576 Sending request-line and headers:
. 2025-10-07 14:54:39.576 Doing DNS lookup on u123456.your-storagebox.de...
. 2025-10-07 14:54:39.584 req: Connecting to 2a01:4f8:2b02:c99::2:443
. 2025-10-07 14:54:39.611 Doing SSL negotiation.
. 2025-10-07 14:54:39.645 ssl: Verify callback @ 2 => 19
. 2025-10-07 14:54:39.645 ssl: Verify failures |= 8 => 8
. 2025-10-07 14:54:39.646 Chain depth: 3
. 2025-10-07 14:54:39.646 Identity match for '': bad
. 2025-10-07 14:54:39.646 ssl: Match common name '*.your-storagebox.de' against 'u123456.your-storagebox.de'
. 2025-10-07 14:54:39.646 Identity match for 'u123456.your-storagebox.de': good
. 2025-10-07 14:54:39.646 Verifying certificate for "*.your-storagebox.de" with fingerprint 34:12:f3:d8:e2:cb:8f:51:82:c7:1d:03:6a:a5:59:0c:f9:5d:60:7f:73:0d:c7:fd:65:02:ed:d7:a4:61:cc:cf and 08 failures
. 2025-10-07 14:54:39.670 Certificate verified against Windows certificate store
. 2025-10-07 14:54:39.670 Using TLSv1.3, cipher TLSv1.3: TLS_AES_256_GCM_SHA384, 4096 bit RSA
. 2025-10-07 14:54:39.670 Request sent; retry is 0.
. 2025-10-07 14:54:39.694 req: Line: HTTP/1.1 401 Unauthorized
. 2025-10-07 14:54:39.694 req: Line: Date: Tue, 07 Oct 2025 12:54:39 GMT
. 2025-10-07 14:54:39.694 req: Header: [date] = [Tue, 07 Oct 2025 12:54:39 GMT]
. 2025-10-07 14:54:39.694 req: Line: Server: Apache
. 2025-10-07 14:54:39.694 req: Header: [server] = [Apache]
. 2025-10-07 14:54:39.694 req: Line: WWW-Authenticate: Basic realm="WebDAV Restricted"
. 2025-10-07 14:54:39.694 req: Header: [www-authenticate] = [Basic realm="WebDAV Restricted"]
. 2025-10-07 14:54:39.694 req: Line: Content-Length: 458
. 2025-10-07 14:54:39.694 req: Header: [content-length] = [458]
. 2025-10-07 14:54:39.694 req: Line: Keep-Alive: timeout=15, max=100
. 2025-10-07 14:54:39.694 req: Header: [keep-alive] = [timeout=15, max=100]
. 2025-10-07 14:54:39.694 req: Line: Connection: Keep-Alive
. 2025-10-07 14:54:39.694 req: Header: [connection] = [Keep-Alive]
. 2025-10-07 14:54:39.694 req: Line: Content-Type: text/html; charset=iso-8859-1
. 2025-10-07 14:54:39.694 req: Header: [content-type] = [text/html; charset=iso-8859-1]
. 2025-10-07 14:54:39.694 req: End of headers.
. 2025-10-07 14:54:39.694 Running post_headers hooks
. 2025-10-07 14:54:39.716 Reading 458 bytes of response body.
. 2025-10-07 14:54:39.716 Got 458 bytes.
. 2025-10-07 14:54:39.716 Read block (458 bytes):
. 2025-10-07 14:54:39.716 [<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
. 2025-10-07 14:54:39.716 <html><head>
. 2025-10-07 14:54:39.716 <title>401 Unauthorized</title>
. 2025-10-07 14:54:39.716 </head><body>
. 2025-10-07 14:54:39.716 <h1>Unauthorized</h1>
. 2025-10-07 14:54:39.716 <p>This server could not verify that you
. 2025-10-07 14:54:39.716 are authorized to access the document
. 2025-10-07 14:54:39.716 requested.  Either you supplied the wrong
. 2025-10-07 14:54:39.716 credentials (e.g., bad password), or your
. 2025-10-07 14:54:39.716 browser doesn't understand how to supply
. 2025-10-07 14:54:39.716 the credentials required.</p>
. 2025-10-07 14:54:39.716 <hr>
. 2025-10-07 14:54:39.716 <address>Apache Server at u123456.your-storagebox.de Port 443</address>
. 2025-10-07 14:54:39.716 </body></html>
. 2025-10-07 14:54:39.716 ]
. 2025-10-07 14:54:39.716 Running post_send hooks
. 2025-10-07 14:54:39.716 auth: Post-send (#0), code is 401 (want 401), WWW-Authenticate is Basic realm="WebDAV Restricted"
. 2025-10-07 14:54:39.716 auth: Got challenge (code 401).
. 2025-10-07 14:54:39.716 auth: Got 'Basic' challenge.
. 2025-10-07 14:54:39.716 auth: Trying Basic challenge...
. 2025-10-07 14:54:39.716 auth: Basic auth scope is: /
. 2025-10-07 14:54:39.716 auth: Accepted Basic challenge.
. 2025-10-07 14:54:39.716 Running pre_send hooks
. 2025-10-07 14:54:39.716 auth: Sending 'Basic' response.
. 2025-10-07 14:54:39.716 auth: '/' is inside auth domain: 1.
. 2025-10-07 14:54:39.716 Sending request headers:
. 2025-10-07 14:54:39.716 OPTIONS / HTTP/1.1
What I don't understand is that it says "Unauthorized" (at: 2025-10-07 14:54:39.716) but authentication works anyway.
What happens after this "Unauthorized"? How does WinSCP authorize to the WebDAV Storage Box exactly?
I ask this, because I have issues with a Plugin in Total Commander, where I cannot access that storage box with WebDAV.
Thanks for hints, frank
EDIT 2025-10-08: the missing part after BASIC AUTH:
. 2025-10-07 14:54:39.716 User-Agent: WinSCP/6.5.3 neon/0.34.2
. 2025-10-07 14:54:39.716 Keep-Alive:
. 2025-10-07 14:54:39.716 Connection: TE, Keep-Alive
. 2025-10-07 14:54:39.716 TE: trailers
. 2025-10-07 14:54:39.716 Host: u123456.your-storagebox.de
. 2025-10-07 14:54:39.716 Authorization: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
. 2025-10-07 14:54:39.716 Sending request-line and headers:
. 2025-10-07 14:54:39.716 Request sent; retry is 1.
. 2025-10-07 14:54:39.743 req: Line: HTTP/1.1 200 OK
. 2025-10-07 14:54:39.743 req: Line: Date: Tue, 07 Oct 2025 12:54:39 GMT
. 2025-10-07 14:54:39.743 req: Header: [date] = [Tue, 07 Oct 2025 12:54:39 GMT]
. 2025-10-07 14:54:39.743 req: Line: Server: Apache
. 2025-10-07 14:54:39.743 req: Header: [server] = [Apache]
. 2025-10-07 14:54:39.743 req: Line: DAV: 1,2
. 2025-10-07 14:54:39.743 req: Header: [dav] = [1,2]
. 2025-10-07 14:54:39.743 req: Line: DAV: <http://apache.org/dav/propset/fs/1>
. 2025-10-07 14:54:39.743 req: Header: [dav] = [<http://apache.org/dav/propset/fs/1>]
. 2025-10-07 14:54:39.743 req: Line: MS-Author-Via: DAV
. 2025-10-07 14:54:39.743 req: Header: [ms-author-via] = [DAV]
. 2025-10-07 14:54:39.743 req: Line: Allow: OPTIONS,GET,HEAD,POST,DELETE,TRACE,PROPFIND,PROPPATCH,COPY,MOVE,LOCK,UNLOCK
. 2025-10-07 14:54:39.743 req: Header: [allow] = [OPTIONS,GET,HEAD,POST,DELETE,TRACE,PROPFIND,PROPPATCH,COPY,MOVE,LOCK,UNLOCK]
. 2025-10-07 14:54:39.743 req: Line: Content-Length: 0
. 2025-10-07 14:54:39.743 req: Header: [content-length] = [0]
. 2025-10-07 14:54:39.743 req: Line: Keep-Alive: timeout=15, max=99
. 2025-10-07 14:54:39.743 req: Header: [keep-alive] = [timeout=15, max=99]
. 2025-10-07 14:54:39.743 req: Line: Connection: Keep-Alive
. 2025-10-07 14:54:39.743 req: Header: [connection] = [Keep-Alive]
. 2025-10-07 14:54:39.743 req: Line: Content-Type: httpd/unix-directory
. 2025-10-07 14:54:39.743 req: Header: [content-type] = [httpd/unix-directory]
. 2025-10-07 14:54:39.743 req: End of headers.
. 2025-10-07 14:54:39.743 Running post_headers hooks
. 2025-10-07 14:54:39.764 Running post_send hooks
. 2025-10-07 14:54:39.764 auth: Post-send (#1), code is 200 (want 401), WWW-Authenticate is (none)
. 2025-10-07 14:54:39.764 Request ends, status 200 class 2xx, error line:
. 2025-10-07 14:54:39.764 200 OK
. 2025-10-07 14:54:39.764 Running destroy hooks.
. 2025-10-07 14:54:39.764 Request ends.
. 2025-10-07 14:54:39.764 Server capabilities: 1, 2, <http://apache.org/dav/propset/fs/1>
. 2025-10-07 14:54:39.765 --------------------------------------------------------------------------
. 2025-10-07 14:54:39.765 Using WebDAV protocol.
. 2025-10-07 14:54:39.766 Doing startup conversation with host.
. 2025-10-07 14:54:39.766 Session upkeep
. 2025-10-07 14:54:39.780 Changing directory to "/".
. 2025-10-07 14:54:39.780 Trying to open directory "/".
. 2025-10-07 14:54:39.781 auth: Create for WWW-Authenticate
. 2025-10-07 14:54:39.781 Running pre_send hooks
. 2025-10-07 14:54:39.781 auth: Sending 'Basic' response.
. 2025-10-07 14:54:39.781 auth: '/' is inside auth domain: 1.
> 2025-10-07 14:54:39.781 <?xml version="1.0" encoding="utf-8"?>
> 2025-10-07 14:54:39.781 <propfind xmlns="DAV:"><allprop/></propfind>
. 2025-10-07 14:54:39.781 Sending request headers:
. 2025-10-07 14:54:39.781 PROPFIND / HTTP/1.1
. 2025-10-07 14:54:39.781 User-Agent: WinSCP/6.5.3 neon/0.34.2
. 2025-10-07 14:54:39.781 Connection: TE
. 2025-10-07 14:54:39.781 TE: trailers
. 2025-10-07 14:54:39.781 Host: u123456.your-storagebox.de
. 2025-10-07 14:54:39.781 Depth: 0
. 2025-10-07 14:54:39.781 Content-Length: 84
. 2025-10-07 14:54:39.781 Content-Type: application/xml
. 2025-10-07 14:54:39.781 Authorization: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
. 2025-10-07 14:54:39.781 Sending request-line and headers:
. 2025-10-07 14:54:39.781 Sending request body:
. 2025-10-07 14:54:39.781 Body block (84 bytes):
. 2025-10-07 14:54:39.781 [<?xml version="1.0" encoding="utf-8"?>
. 2025-10-07 14:54:39.781 <propfind xmlns="DAV:"><allprop/></propfind>
. 2025-10-07 14:54:39.781 ]
. 2025-10-07 14:54:39.781 Request sent; retry is 1.
. 2025-10-07 14:54:39.807 req: Line: HTTP/1.1 207 Multi-Status
. 2025-10-07 14:54:39.807 req: Line: Date: Tue, 07 Oct 2025 12:54:39 GMT
. 2025-10-07 14:54:39.808 req: Header: [date] = [Tue, 07 Oct 2025 12:54:39 GMT]
. 2025-10-07 14:54:39.808 req: Line: Server: Apache
. 2025-10-07 14:54:39.808 req: Header: [server] = [Apache]
. 2025-10-07 14:54:39.808 req: Line: Content-Length: 845
. 2025-10-07 14:54:39.808 req: Header: [content-length] = [845]
. 2025-10-07 14:54:39.808 req: Line: Content-Type: text/xml; charset="utf-8"
. 2025-10-07 14:54:39.808 req: Header: [content-type] = [text/xml; charset="utf-8"]
. 2025-10-07 14:54:39.808 req: End of headers.
. 2025-10-07 14:54:39.808 Running post_headers hooks
. 2025-10-07 14:54:39.808 Reading 845 bytes of response body.
. 2025-10-07 14:54:39.808 Got 845 bytes.
. 2025-10-07 14:54:39.808 Read block (845 bytes):
. 2025-10-07 14:54:39.808 [<?xml version="1.0" encoding="utf-8"?>
. 2025-10-07 14:54:39.808 <D:multistatus xmlns:D="DAV:" xmlns:ns0="DAV:">
. 2025-10-07 14:54:39.808 <D:response xmlns:lp2="http://apache.org/dav/props/" xmlns:lp1="DAV:">
. 2025-10-07 14:54:39.808 <D:href>/</D:href>
. 2025-10-07 14:54:39.808 <D:propstat>
. 2025-10-07 14:54:39.808 <D:prop>
. 2025-10-07 14:54:39.808 <lp1:resourcetype><D:collection/></lp1:resourcetype>
. 2025-10-07 14:54:39.808 <lp1:creationdate>2025-09-27T17:23:13Z</lp1:creationdate>
. 2025-10-07 14:54:39.808 <lp1:getlastmodified>Sat, 27 Sep 2025 17:23:13 GMT</lp1:getlastmodified>
. 2025-10-07 14:54:39.808 <lp1:getetag>"5-63fcba83b1f0a"</lp1:getetag>
. 2025-10-07 14:54:39.808 <D:supportedlock>
. 2025-10-07 14:54:39.808 <D:lockentry>
. 2025-10-07 14:54:39.808 <D:lockscope><D:exclusive/></D:lockscope>
. 2025-10-07 14:54:39.808 <D:locktype><D:write/></D:locktype>
. 2025-10-07 14:54:39.808 </D:lockentry>
. 2025-10-07 14:54:39.808 <D:lockscope><D:shared/></D:lockscope>
. 2025-10-07 14:54:39.808 </D:supportedlock>
. 2025-10-07 14:54:39.808 <D:lockdiscovery/>
. 2025-10-07 14:54:39.808 <D:getcontenttype>httpd/unix-directory</D:getcontenttype>
. 2025-10-07 14:54:39.808 </D:prop>
. 2025-10-07 14:54:39.808 <D:status>HTTP/1.1 200 OK</D:status>
. 2025-10-07 14:54:39.808 </D:propstat>
. 2025-10-07 14:54:39.808 </D:response>
. 2025-10-07 14:54:39.808 </D:multistatus>
. 2025-10-07 14:54:39.808 ]
. 2025-10-07 14:54:39.808 XML: Parsing 845 bytes.
Re: WebDAV - HTTP Basic Auth
That's a normal flow of the HTTP authentication. You try to connect, the server responds with 401 Unauthorized and WWW-Authenticate header – announcing that it needs authorization to allow an access and what authentication methods it does support (Basic in this case).
The client (WinSCP) then uses this information to send appropriate authorization request (you didn't include this part of the log).
franc
franc avatar
Thanks!
I guess the Total Commander WebDAV Plugin is not able to switch to BASIC AUTH after the "normal" Login failed.
I will add this information to the plugin forum :)
...The client (WinSCP) then uses this information to send appropriate authorization request (you didn't include this part of the log).
I added it (EDIT) to my first post.
