The FTP connection using WinSCP.Session via SSH tunnel does not work.
kuzyaka
Using sshcPulkovo As SshClient = New SshClient(ciPulkovo)
  sshcPulkovo.Connect()
  If sshcPulkovo.IsConnected Then
    Dim intProxyPort As UInt16 = 5534
    Dim portDynamic As New ForwardedPortDynamic(intProxyPort)
    sshcPulkovo.AddForwardedPort(portDynamic)
    portDynamic.Start()
    If portDynamic.IsStarted Then
      For Each RowСклад As DataRow In dtСклад.Rows
        'ЗагрузитьФотоПоFTP(strФотоНасервере)
        With sessionOptions
          .Protocol = Protocol.Ftp
          .HostName = "192.168.0.1"
          .UserName = "anonymous"
          .Password = ""
        End With
        'Next
        Using session As New Session
          ' Подключиться
          session.Open(sessionOptions)
          strФотоНасервере = "Фото/" & intIDPostavshik & "/" & RowСклад("Article") & ".jpg"
          imgFoto = GetImageFromFTP(strФотоНасервере)
          RowСклад("Image") = УменьшитьФото(intFrameHeight, intFrameWidth, imgFoto)
          imgFoto.Dispose()
        End Using
      Next
    End If
    portDynamic.Stop()
  End If
End Using
At the same time, connect to FTP using WinSCP.exe the SSH tunnel is working fine.
Using scPulkovo As New SshClient(ciPulkovo)
  Try
    scPulkovo.Connect()
    If scPulkovo.IsConnected Then
      If ПроверкаНаличияСервераTelnet(strHostName, 21) Then
        scPulkovo.AddForwardedPort(portDynamic)
        portDynamic.Start()
            Dim ProcessWinSCP As New Process
            ProcessWinSCP.StartInfo.FileName = "WinSCP.exe"
            ProcessWinSCP.StartInfo.Arguments = "data@" & strHostName & ""
            ProcessWinSCP.Start()
            ProcessWinSCP.WaitForExit()
            ProcessWinSCP.Close()
            portDynamic.Stop()
          Else
            MessageBox.Show("Ошибка при создании туннеля!",
                                    "WinSCP",
                                    MessageBoxButtons.OK,
                                    MessageBoxIcon.Error)
          End If
          scPulkovo.RemoveForwardedPort(portDynamic)
        End If
      End If
    End If
  Catch ex1 As Exception
    MessageBox.Show("Ошибка при создании туннеля!" & vbCrLf & ex1.Message,
                        "WinSCP",
  End Try
Re: The FTP connection using WinSCP.Session via SSH tunnel does not work.
It's not clear from your code, where is the winscp.exe connecting. What is data@strHostName? It might be GUI-configured session that uses the intProxyPort.
In neither of your code you are actually using the forwarded port intProxyPort.
You have to use it to configure WinSCP to use proxy.
Please, post session log files from both codes, if you want us to check what exactly is happening.
