Remeber columns by path
lukasradek
Czechia
Add an option that allows the user to customize columns (name, size, dates, etc.) and their sorting (asc, desc) per directory path.
I often need to browse different directories in which some are much better to be viewed alphabetically, while others in reversed alphabetical order.
It would be really helpful for productivity to have these settings remembered per directory.
