PowerShell SFTP Call failing with Error 77
I am scripting a PowerShell solution for automated file transfer using the WINSCP library
The session preparation code is as follows
try {
# Load WinSCP .NET assembly
Add-Type -Path "C:\Program Files (x86)\WinSCP\WinSCPnet.dll"
# Setup session options
$sessionOptions.Protocol = [WinSCP.Protocol]::Sftp
$sessionOptions.HostName = "fmisoic01.prod.services"
$sessionOptions.UserName = $SFTPIdentity
$sessionOptions.SecurePassword = $Password
$sessionOptions.AddRawSettings("PreferredHostKeyAlgorithm", "ssh-rsa")
$sessionOptions.AddRawSettings("HostKeyAlgorithms", "ssh-rsa")
# Required host key
$sessionOptions.SshHostKeyFingerprint = $HostFingerprint
The Following is being pushed to the logs
2025-12-09 14:58:58 : === SFTP TRANSFER START ===
2025-12-09 14:59:07 : ERROR: Exception calling "Open" with "1" argument(s): "SFTP protocol violation: Invalid response message type (77).
Error getting name of current remote directory."
2025-12-09 14:59:07 : === SFTP TRANSFER END ===
If I connect to the same target server with full logging via the GUI it is faulting as follows
< 2025-12-08 12:22:44.953 Type: Unknown message (77), Size: 14, Number: 1634890857
< 2025-12-08 12:22:44.953 4D,61,72,74,69,6E,20,50,72,69,6B,72,79,6C,
. 2025-12-08 12:22:44.953 Attempt to close connection due to fatal exception:
* 2025-12-08 12:22:44.953 SFTP protocol violation: Invalid response message type (77).
This seems to be related to the issue outlined in https://winscp.net/forum/viewtopic.php?t=33496, I am looking for how to not trip on this configuration issue in a scripted scenario
Is anyone able to help me sort out my connection to this recalcitrant server?
try {
# Required host key
