WinSCP process terminated with exit code 3. There was no output.
roller_cosmonavt
Hi, everyone!
Been running the .NET version for years. Recently though we have been getting the following error:
WinSCP process terminated with exit code 3. There was no output. Response log file C:\Windows\TEMP\wscp1688.019FD045.tmp was not created. This could indicate lack of write permissions to the log folder or problems starting WinSCP itself.
There is no log created, and even when I enable logging this error does not log.
A reboot solves it for 3-4 days, but it comes back every time. Once it hits, then any further communication is dead...and everything continues to fail until a reboot.
I am using 6.3.2 version WinSCP
There are no stale processes WinSCP in the Task Manager.
I am attaching the log file
Do you have any idea what could be causing this?
Re: WinSCP process terminated with exit code 3. There was no output.
I'm sorry, but I have no clue. How many sessions does it take for the problem to appear?
martin.jakob
I guess I have the same problem on Windows Server 2019 using WinSCP 6.5.5. Every couple of days, a few of our uploads fail with the error message: "WinSCP process terminated with exit code 3."
I usually works again the next time without a reboot being necessary.
I've attached a log file, I anonymized the SFTP server address in it.
Could you maybe send me the debug version?
