Receiving non-lvalue error when trying to set SessionLogPath in Perl
Ully
UK
I'm trying to create a new session and I want to set a SessionLogPath on a Windows host.
# Initialize for Session
my $session = Win32::OLE->new('WinSCP.Session');
$session->SessionLogPath = "D:/SCP_Workflow_Logs/";
When I reach this point in the code I get the error:
Can't modify non-lvalue subroutine call at ********* line 1295.
Does anyone know what's causing this?
Ully
RESOLVED: Receiving non-lvalue error when trying to set SessionLogPath in Perl
Discovered through the GitHub that you have to use SetSessionLogPath() to set this value. This isn't in the documentation on the winscp.net website.
Re: Receiving non-lvalue error when trying to set SessionLogPath in Perl
I do not know much about Perl, but our Perl documentation shows that a syntax for setting properties is like:
$sessionOptions->{'SessionLogPath'} = ...;
See Using WinSCP .NET Assembly from Perl (ActivePerl).
Also the SessionOptions.SessionLogPath takes a path to a file, not to a folder.
So it should be like:
$sessionOptions->{'SessionLogPath'} = "D:/SCP_Workflow_Logs/session.log";
