Change search feature
EmilienR
I migrated after using FileZila for 6 years, and currently I struggle with the search feature.
In filezilla, if you used "ctrl+f" it was doing in live a filter with name containing what you are tiping.
For example if I ctrl + f "test" it will only display all file containing "test".
When you got tons of file and want to only display some of them to do a bulk opening/search, it's way easier.
There is nearly the same feature with the search but too limited :
- Need to place * at the start and the end (like *test*)
- It's not live search
- If I want to clear/edit the search, I need to reopen it
For me that's the only drawbawk of WinSCP, for everything else I found a solution
Kind regards.
