WinSCP Key-Based Auth Issue in Parallel Migration (2012 → 2022 Server)
lascrams
Las Vegas
Hi all,
I have an existing Windows Server 2012 server running WinSCP scripts successfully using key-based authentication. I’m now building a new Windows Server 2022 server and want to run it in parallel during testing before decommissioning the 2012 server.
I copied the WinSCP scripts and key files to the new server, but the jobs fail there, while the same process continues to work fine on the 2012 server.
I’m trying to confirm whether, in a parallel setup, I can reuse the same existing key pair on the new server, or if I need to generate a new key pair from the 2022 server and provide the new public key to the vendor.
Any insight would be appreciated.
Re: WinSCP Key-Based Auth Issue in Parallel Migration (2012 → 2022 Server)
Yes, in general you can use the same key pair. The problem is likely elsewhere.
Please attach a full session log file showing the problem (preferably logs from both machines).
