Host key does not match
kibs1221
My log shows the correct host key then shows another one where I do not know where it is coming from??
Host key fingerprint is:
. 2026-04-02 14:35:38.189 Host key fingerprint is:
. 2026-04-02 14:35:38.192 ssh-rsa 4096 SHA256:ALNmZ9wqf4E3z0rPj5GIuqzsE/KlPsVonq4LFx8Q7D0
< 2026-04-02 14:35:38.195 Script: Authenticating...
. 2026-04-02 14:35:38.198 Host key does not match configured key fingerprint ssh-rsa 2048 3jr8XXVhHnCgbIENSj0VFK0I8nMwoTOjiaWTCiY/zNU
. 2026-04-02 14:35:38.201 Attempt to close connection due to fatal exception:
* 2026-04-02 14:35:38.204 Host key fingerprint is ssh-rsa 4096 ALNmZ9wqf4E3z0rPj5GIuqzsE/KlPsVonq4LFx8Q7D0.
* 2026-04-02 14:35:38.206 (Exception) **Host key does not match configured key fingerprint "ssh-rsa 2048 3jr8XXVhHnCgbIENSj0VFK0I8nMwoTOjiaWTCiY/zNU"!**
. 2026-04-02 14:35:38.209 Closing connection.
< 2026-04-02 14:35:38.214 Script: Host key does not match configured key fingerprint "ssh-rsa 2048 3jr8XXVhHnCgbIENSj0VFK0I8nMwoTOjiaWTCiY/zNU"!
< 2026-04-02 14:35:38.216 Host key fingerprint is ssh-rsa 4096 ALNmZ9wqf4E3z0rPj5GIuqzsE/KlPsVonq4LFx8Q7D0.
< 2026-04-02 14:35:38.219 Authentication failed.
The correct one is the ssh-rsa 4096 SHA256:ALNmZ9wqf4E3z0rPj5GIuqzsE/KlPsVonq4LFx8Q7D0
This is my text file -
open sftp://sftp-jefferson:FiYvSbdTKQ4PGDNm7Nrp@sftp.siftwell.ai/ -hostkey="ssh-rsa 4096 ALNmZ9wqf4E3z0rPj5GIuqzsE/KlPsVonq4LFx8Q7D0"
Reply with quote E-mail
Re: Host key does not match
kibs1221
i have attached a batch log
  • job_log.txt (159.25 KB, Private file)
Description: attached a batch job log with error
Re: i have attached a batch log
The log file you have posted contains logs of many sessions to the same server. Each log showing a different host key provided in the batch file. And some of the sessions actually do succeed:
> 2026-04-02 15:36:56.539 Script: open sftp://sftp-jefferson:***@sftp.siftwell.ai/ -hostkey="ssh-rsa 4096 ALNmZ9wqf4E3z0rPj5GIuqzsE/KlPsVonq4LFx8Q7D0"
. 2026-04-02 15:36:56.728 Have a known host key of type rsa2
. 2026-04-02 15:36:56.758 Doing ECDH key exchange with curve Curve25519, using hash SHA-256
. 2026-04-02 15:36:56.934 Host key fingerprint is:
. 2026-04-02 15:36:56.937 ssh-rsa 4096 SHA256:ALNmZ9wqf4E3z0rPj5GIuqzsE/KlPsVonq4LFx8Q7D0
< 2026-04-02 15:36:56.939 Script: Authenticating...
. 2026-04-02 15:36:56.942 Host key matches configured key fingerprint
