Nextcloud public shares with password - Auth failure
fufu65
WinSCP versions: 6.5.6 and 6.6.1 beta - GUI
MS Windows 10 Pro 22H2 and 11 Pro 25H2
WebDAV - NextCloud versions 32.0.8 and 33.0.2
I have problems connecting to Nextcloud public shares, only if a password is requested.
With private shares (Nextcloud path /remote.php/dav/files/USERNAME) there are no problems, the auth process is ok and the credentials are accepted.
With public shares (Nextcloud path /public.php/dav/files/USERNAME) there are no problems if no password is set on the share, but if a password is required this error occurs: "401 Unauthorized - Connection failed."
With rclone and Cyberduck there are no problems at all, so I think it's a bug of WinSCP.
Fulvio
  • NextCloud-public-share-test.log (8.82 KB, Private file)
