How to Automatically Sync Local Folder with Server Using WinSCP?
emmawalters267@gmail.com
usa
Hi everyone,
I’m currently using WinSCP to transfer files between my local computer and a remote server, and overall the experience has been great.
I would like to know if there is a reliable way to automatically synchronize a local folder with the server without manually uploading files every time I make changes.
My goal is:
When I update files locally, they automatically upload to the server
Avoid re-uploading unchanged files
Possibly run the sync on a schedule or via script
I’ve seen options like Keep Remote Directory Up to Date and scripting features, but I’m not sure which method is best for long-term automation.
Could anyone share:
Recommended sync settings
Example WinSCP script or automation workflow
Any common mistakes to avoid?
Thanks in advance for your help!
