WinSCP no longer deleting files on Ubuntu 26
Majed
belarus
Peace, the !requiretty was removed from sudo in the mentioned version of Ubuntu so I am unable to scp files from it.
here is the sudoers configuration:
user ALL=(ALL) NOPASSWD: ALL
The connection is configured for scp and in the more tab, sudo su - is set. How to make it work when !requiretty can not be configured in sudoers?
Re: WinSCP no longer deleting files on Ubuntu 26
I do not know anything about it. But consulting with Gemini, it claims that although the !requiretty is not longer supported, it's actually the default configuration. So there should be no change in behaviour.
So what exact problem do you have now? Can you login when sudo su - is set as a shell? If you can, the problem is probably not about !requiretty.
SFTP is perm, user, group based. If anything changes such as copying files outside of it or from a client with another user, it can see problems with access.
