Error while getting file from FTP. Size of file – more 2TB.
Michael
Using this command
Get  -preservetime -resume DWHFull.bak "D:\BackUp\Temp\DWHFull\"
When size of file more 2TB, some time getting error :
  <failure>
    <message>Error transferring file '/DWH/DWHFull.bak'.</message>
    <message>An unknown error occurred while accessing D:\BackUp\Temp\DWHFull\DWHFull.bak.</message>
    <message>Copying files from remote side failed.</message>
    <message>The specified network name is no longer available. </message>
  </failure>
And I can not continue getting file with key -resume. I delete partial file and restart downloading. When size of file less than 2TB, all ok, key -resume - working.
Got anyone this error in same situation (big size of file)?
I think 100% problem is in overflow when WinSCP getting file size. It show in screenshot. This is a reason error when use -resume key. I have received same problem when this situation testing in GUI WinSCP with resume mode.
Using WinSCP for backup bases. I don't want mapping disk.
Re: Error while getting file from FTP. Size of file – more 2TB.
It's probably a server-side problem.
Or can you download the file using any other FTP client?
Please post session log file, if you want us to investigate further.
Larger the file size the larger the risk of getting it all transferred. It tends to shake out problems :)
A lot of software tends to not get tested the larger or more numerous things get. There's a certain point where its pushing a limit of what gets tested.
So maybe the server here has issues with larger than 2 TB or maybe you're out of storage space. There's 100 or 1,000 things it could be.
