Feature Request: Keep Login window open when opening PuTTY session
maisondasilva
Customer
maisondasilva avatar
Brazil
I would like to suggest a small usability improvement for WinSCP regarding the login window behavior when opening PuTTY sessions.
I often use WinSCP as my main SSH session manager. When I right-click a saved session and choose “Open in PuTTY”, the WinSCP login window closes automatically after launching PuTTY.
It would be very useful to have an optional setting such as:
“Keep login window open after opening session in PuTTY”
This would allow users to quickly open multiple SSH sessions one after another without needing to reopen WinSCP or click “New Tab” repeatedly.
For users who manage many servers or SSH connections, this could significantly improve workflow and convenience.
Thank you for the great software and for considering this suggestion.
maisondasilva
Customer
Is it possible for this feature to be included in the new version 6.6? I’d be willing to make a donation if necessary, as it would really help me out—I almost always forget to press Shift. It would be great to have an option on the login screen to enable or disable this.
https://maisondasilva.com.br
Microsoft MVP Windows and Devices
