Previously working script not working anymore
jhs1
Here is my script which I run from a cmd prompt in Windows, it first prompts for the web site password then uploads 1 file:
@echo off
setlocal enableextensions enabledelayedexpansion
set /P password=Enter website pwd or Enter to quit:
IF %password% == "" exit
cls
set log_filename=passwd_upload.log
del %log_filename%
echo Starting WinSCP
"C:\Program Files (x86)\WinSCP\WinSCP.com" /log=%log_filename% /ini=nul /command "open ftp://xxx:"%password%"@ftp.xxx.com:21/ -hostkey=""ssh-ed25519 255 yyyyyyyyy"" -rawsettings FSProtocol=2" ^
 "put ""C:\file"" ""/home/xxx/file""" ^
 "exit"
echo WinSCP finished
set /P exit_bat=Hit any key to quit:
Description: log file from doing the same via the WinSCP UI (which works)
Re: Previously working script not working anymore
We need to know more about "not working anymore". What does it do? Can you please post the script passwd_upload.log log file too?
