Can't drag a remote file to local
PEU
Buenos Aires, Argentina
I cannot repeat this consistently, but when I attempt to drag a file from the remote pane while I'm in split view sometimes it takes 3 or 4 times to click on the file for the copy feature to be activated and I can copy it to the local pane via mouse drag.
Re: Can't drag a remote file to local
Thanks for your report. Can you please post a screen recording to document the problem?
PEU
Since started using the version you sent me, not a single time I was able to reproduce the bug on two different computers running Win11 up to date. Maybe this is a bug report by the negative dunno lol
