Password is invalid using WinSCP 5.7
donb1
us
I use WinSCP 5.7 with Win10, Password for Zorin 18.1 is OK when logging in.
Found my PROPER IP For Zorin and used it, password is same used to login, but WinSCP 5.7 doesn't allow it to stick and login to Zorin 18,1 or Windows 19 to show Windows/Linux Panels as it should?
Description: Zorin Network
Re: Password is invalid using WinSCP 5.7
Sorry, I'm not sure I understand what you mean by "doesn't allow it to stick".
Are you asking how to save your (new?) password to WinSCP?
