Memory Leak using S3
Toni76
When deleting a large number of foldes/subfolders/files in an S3 storage, the application runs out of memory:
  • WinSCP shows an error message box (Cancel/Try again/Skip/...): "SSL handshake failed: SSL error: malloc failure"
  • Windows Task Manager shows ~3.9 GB allocated for WinSCP.exe, slightly below the 4 GB limit.
    Cancelling the task results in expectable subsequent errors ("Invalid access to memory location.") but not in memory being released, according to Task Manager.
Using WinSCP 6.7 (Build 17845 2026-10-14) on Windows 10 22H2 64-bit.
Re: Memory Leak using S3
Sorry, I wanted to write "Is this NEW problem in some recent version of WinSCP?".
Anyway, I hope I have identified the problem:
Issue 2476 – Memory leak in encrypted HTTP/S3/WebDAV connections
Though it involves rather a lot of small requests to the server, rather than large transfers (a small number of large requests). Still I hope it might be the same problem.
Toni76
Thank you, the dev version works well!
A very quick fix. :-)
I am deleting millions of files, so this was quite a "big" leak.
The new version started at ~14 MB in task manager and after about half an hour it is at ~16 MB. So maybe there is another small leak, but could also be usual or wanted behavior.
