Option to keep dialogs in light theme while main window uses dark theme
webman
Germany
Hi there,
since WinSCP 6.6, the dark theme also applies to the Login dialog, message boxes, progress windows etc. Before that, the main window was dark while these dialogs stayed light.
For me, the previous mix was actually more comfortable: the dark main window is easy on the eyes, but text in the dark dialogs is harder to read for me. Switching the whole application to the light theme is not an option, as it’s too bright.
Would it be possible to add a preference (e.g. under Environment > Interface) to choose the theme for dialogs separately, or to keep dialogs light while using the dark theme?
Thanks for the great tool!
Tanja
Re: Option to keep dialogs in light theme while main window uses dark theme
Thanks for your suggestion.
We will see, if more people ask for this.
