Feature request: Reusable proxy profiles (select from list instead of per-site configuration)
I manage dozens of servers in WinSCP and frequently need to switch between several different proxies (different types, hosts, ports, and credentials) depending on the target server.
Currently, proxy settings live under Advanced Site Settings → Connection → Proxy and must be entered manually for every site. When a proxy changes (or when I need to reassign proxies across many sites), updating everything becomes extremely time-consuming.
I would find it very useful to have a separate, central place where proxies can be defined and named once (type, host, port, username, password, and other relevant options). Then, on each site’s Proxy page, there would be a simple dropdown to select one of the predefined proxies (or "None"), plus an "Add…" button that opens the proxy-creation dialog directly.
This would make it practical to:
Thank you for considering this. WinSCP is an excellent tool and this small change would save a lot of time for users who work with many sites and multiple proxies.
Best regards.
Maintain a small list of proxies in one place
Assign or reassign them quickly to many sites
Update a proxy once and have the change apply everywhere it is used
Best regards.
