Connect to FTP/SFTP server
This guide contains simplified description of connecting to FTP or SFTP server with WinSCP. Before starting you should have WinSCP installed.
Collecting Session Details
  • Host name1 of the server2
  • Protocol the server supports (FTP, SFTP, FTPS, etc.)
  • Username
  • Password3
If you do not know these details, ask administrator of the system you are trying to connect to. If you have an account on a file server at your place of work, or at the company which hosts your website (for example), you should contact their IT Support department to be reminded of your logon details.
Connecting
  • Select Session tab (it will be selected already if you are using WinSCP for the first time).
  • Select you File protocol. When you are about to use FTPS protocol, select FTP and then choose one of the FTPS invocation methods.
  • You may want to save your session details to stored session so you do not need to type them in every time you want to connect. Press Save button and type stored session name.
  • Press Login to connect.
  1. Or IP addressBack
  2. When you are trying to connect to iPhone/iPod Touch, replace term “server” on these pages with iPhone/iPod Touch. Learn how to connect to iPhone/Ipod Touch.Back
  3. Or other mean of authentication.Back
Last modified: by martin – Currently locked by: 46.246.144.92
