Before Starting
- Protocol: SFTP - Host: sftp:hydras.ugent.be - Port: 2225 - Username: gleamuser - Password: GLEAM4#h-cel#83
Connecting
  • Select your File protocol.
    When you are about to use FTPS protocol (FTP over TLS/SSL, not SFTP), select
    FTP and then choose one of the FTPS invocation methods).
  • You may want to save your session details to a site so you do not need to type them in whenever you want to connect. Press the Save button and type the site name.
  • Press Login// to connect.
Last modified: by 120.236.174.225 – Currently locked by: 196.196.222.103
