SFTP transfer viewing moved files
sci400
Using FTP the program allows me to move files from my PC to the connected host. However, under SFTP with one of my customers after I move the file one of two things happen. The file shows up on the remote server as different name (but the size is the same) or I am unable to see the file at all on the remote server. This does not happen with all the FTP connections we have setup. This issue is making it difficult for users to validate if the files were sent or not. I could have them look at the log but that is not the easiest document to read from a non-technical users point of view. We have tried many versions of winscp but the current version we are using is 5.9 build 6786.
Thanks in advance for any assistance on this issue.
Re: SFTP transfer viewing moved files
sci400
Log
Ran the transfer this afternoon and all files appeared to be transferred but still unable to see them on the remote server. On many of the large files received an error that required me to select 'NO' and the program would delete the partial file and restart the transfer. in all cases it appeared to have worked but by not seeing it on the remote server it is once again difficult to validate that it was sent.
Thanks again. Log attached
