Moving Files that have been successfully uploaded
JimmyFree
(Perhaps I should post here for help?)
There is a script that permits Moving Files to New Directory After Successful Upload. It is here: https://winscp.net/eng/docs/script_local_move_after_successful_upload
When I run it, it reports success, but the file never shows at its destination.
When I transferred using the GUI, it said it was successful, but had an error because it could not set the timestamp. When I turned off preserving timestamp in the GUI, then transfer worked.
How do I modify the above script so that it turns off setting the timestamp?
THANKS!
JimmyFree
jrp78 wrote:
https://winscp.net/eng/docs/message_preserve_time_perm
Thanks for your reply.
I am aware of this posting. Unfortunately I do not know how to deploy it within the script that I mentioned. Can you show me?
JimmyFree
jrp78 wrote:
Can you post your actual script?
param (
    $localPath = "C:\upload\*",
    $remotePath = "/home/user/",
    $backupPath = "C:\backup\"
try
    # Load WinSCP .NET assembly
    Add-Type -Path "WinSCPnet.dll"
    # Setup session options
        HostName = "example.com"
        UserName = "user"
        Password = "mypassword"
        SshHostKeyFingerprint = "ssh-rsa 2048 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx"
    try
        # Connect
        # Upload files, collect results
        $transferResult = $session.PutFiles($localPath, $remotePath)
        # Iterate over every transfer
        foreach ($transfer in $transferResult.Transfers)
            # Success or error?
            if ($transfer.Error -eq $Null)
                Write-Host ("Upload of {0} succeeded, moving to backup" -f
                    $transfer.FileName)
                # Upload succeeded, move source file to backup
                Move-Item $transfer.FileName $backupPath
            else
                Write-Host ("Upload of {0} failed: {1}" -f
                    $transfer.FileName, $transfer.Error.Message)
    finally
        # Disconnect, clean up
        $session.Dispose()
    exit 0
catch [Exception]
    Write-Host ("Error: {0}" -f $_.Exception.Message)
    exit 1
It reports that it works, but I don't see the file appearing on the other end. I know the destination server will not permit permission and timestamp changes. So I need to disable these.
Thanks much for your help!
vinicostasantos
Brasil
Hi Jimmy,
I have this script working here.
I'll show you my script and maybe you can solve your problem:
*A tip: DoubleCheck your Winscp software version and Windows permissions.
My Winscp version is: 5.7.7
try
    Add-Type -Path "C:\WinSCP\WinSCPnet.dll"
    $sessionOptions.Protocol = [WinSCP.Protocol]::Sftp
    $sessionOptions.HostName = "*****"
    $sessionOptions.UserName = "*****"
    $sessionOptions.Password = "*****"
    $sessionOptions.SshHostKeyFingerprint = "*****"
try
        # Connect
        $localPath =  "******"
        $remotePath = "******"
        $backupPath = "******"
            # Success or error?
                Write-Host ("Upload of {0} succeeded" -f
                    $transfer.FileName)
            else
    finally
        $session.Dispose()
    exit 0
catch [Exception]
    Write-Host $_.Exception.Message
    exit 1
JimmyFree
[quote="vinicostasantos"]Hi Jimmy,
Thanks very much! Will check all of this out now.
JimmyFree
vinicostasantos wrote:
try
try
        # Connect
            # Success or error?
                    $transfer.FileName)
            else
    finally
        $session.Dispose()
    exit 0
catch [Exception]
    exit 1
Thanks for your help. This script works.
I wonder, however, how it may be edited to rename the uploaded files before archiving them. This is important because if the file to be ARCHIVED has the same name as another ARCHIVED file, the archive fails.
JimmyFree wrote:
I wonder, however, how it may be edited to rename the uploaded files before archiving them. This is important because if the file to be uploaded has the same name as another file, the upload fails.
Before archiving or before uploading?
Before Archiving.
JimmyFree
Sorry. Thought I was logged in.
I would like the file renamed before archiving it - appending a timestamp would be awesome.
Really curious to see how this is done.
THANKS!!
