Which "option batch" value to use in order selecting the "Retry" option ?
PlanetIrata
Hi, I'm using the synchronize command and it seems that ther is no "option batch" value that will select "Retry" when a file upload fails :
- If I use "option batch continue", the script will choose "Skip" and synchronize command continue without reporting the upload error in the XML log.
- If I use "option batch on", the script will stop when the file upload fails, and report an error.
Is there a "option batch xxxxx" that could select the "Retry" choice in synchronize when an upload error occurs ?
Thanks.
Re: Which "option batch" value to use in order selecting the "Retry" option ?
"upload error" is too broad description. What specific error are you getting?
Note that there's no way to make WinSCP retry on any possible error.
Here is an "upload error" sample log when a big file transfer fails and can't be resumed because the APPE command is not supported :
_media\atd-distribution081310-spellchecker-server.tgz       |      73504 KiB |   76,0 KiB/s | binary |  69%
Lost connection.
Disconnected from server
(A)bort, (R)econnect (5 s): Reconnect
Connecting to ftpperso.free.fr ...
Connected with ftpperso.free.fr. Waiting for welcome message...
Connected
Starting the session...
Reading remote directory...
Session started.
_media\atd-distribution081310-spellchecker-server.tgz       |      73584 KiB |   77,0 KiB/s | binary |  69%
_media\atd-distribution081310-spellchecker-server.tgz       |            0 B |    0,0 KiB/s | binary |   0%
Error transferring file '_media\atd-distribution081310-spellchecker-server.tgz'.
'APPE': command unrecognized.
(A)bort, (R)etry, (S)kip, Ski(p) all: Skip
WinScp choose "Skip", and do NOT log any error in the XML log file. It would be very useful to have these improvements :
- an option to say to WinSCP to (R)etry at least 3 times (for instance)
- if the failure persists after 3 tries, having a <result success="FALSE" /> in the XML log file (for now the failed upload do not appear anywhere in the XML log file).
Thanks.
Retrying unsupported command does not help.
You have to tell WinSCP no to try to resume at all using -resumesuport=off
https://winscp.net/eng/docs/scriptcommand_put#resumesupport
That happens with the option batch continue more only, right?
Thanks Martin, yes I use option batch continue.
I tried adding -resumesupport=off to synchronize command, and it now retries to upload a file from start when disconnected. It is a more predictable behavior, but the best of both world would be a sort of --resumesupport=auto that would use on if the APPE is supported, and off if not, depending on the server capabilities.
Do you think it's possible ?
Will see if more people ask for this.
Thanks anyway for your great work !
