home directory shows <root> but stays empty.
yasmine
Hey, I recently installed WinSCP for my website (am using Windows 10).
I established the FTP connection but it shows only an (empty) folder called /<root>.
I have tried and failed to fin the cause of my problem.
I added a screenshot of the program. Can someone help me, please.
Re: home directory shows <root> but stays empty.
And the problem is?
Should you see some files? Are there any files on the FTP server?
Can you see the files using any other FTP client?
Jeroen66
Target FTP site is strange / unusable
After update 5.9.2 cannot see target folder correctly. Something is displayed, but for example what used to be a folder look like a file with 0kb size. clicking on it gives error.
yasmine
Yes, it was empty on several FTP servers I tried.
But I downloaded the SFTP file again and installed it again from the beginning, and the files of my website did show after that.
So, the problem is fixed.
Thank you,
Re: Target FTP site is strange / unusable
What version were you using previously?
