Keep permissions of overwritten file when moving to trash
Libik
In certain directory I have file premissions set to 0755. Using remote trash the file to be ovewritten is moved to trash and new file is stored, however it has 0644 but I want to keep the same permission 0755. Is that somehow possible?
Thanks!
Re: Keep permissions of overwritten file when moving to trash
Libik
Here it comes.
Moved file in trash preservers its permissions while the new one has 0644
  • winscp.png (20.8 KB, Private file)
  • test.log (25.78 KB, Private file)
Thanks for the log.
It's the ascii mode that (incorrectly) prevents WinSCP from restoring the permissions. Turn it off, if possible. I'll look into this.
While I am not registered, please use attached one.
  • adr.PNG (775 Bytes, Private file)
I have sent you an email with a debug version of WinSCP.
