SSL3 alert write: fatal: protocol version with WinSCP 5.9.2
EdTechSV
We are using the most recent version of WinSCP 5.9.2 and are receiving the error mentioned below when we attempt to perform an FTP file transfer over port 21. The Minimum TLS/SSL is set to TLS 1.0 and the Maximum TLS/SSL is set to TLS 1.2. The Reuse TLS/SSL session ID for data connections is checked. Our directory options are default settings.
shutdown while in init
wrong version number
Disconnected from server
Error listing directory '/'.
The error occurs on a Windows 2012 R2 server. The error does not occur with the same version of WinSCP 5.9.2 and the same settings to the same Host on a Windows 10 workstation. Our directory options are default settings and the same between our server and my workstation.
Re: SSL3 alert write: fatal: protocol version with WinSCP 5.9.2
Please attach a full session log file on level Debug 2 from both setups.
EdTerchSV
Attched is our log file with names and ip addresses changed.
Thank you for your assistance.
  • WinSCP_Log.log (9.28 KB, Private file)
Description: Attched is our log file with names and ip addresses changed.
"from both setups", please. Add a Windows 10 log of a working session.
