Disabling temporary file name during transfert
Patchi
I put file on a SFTP server successfully with the user interface.
But, I run it as a script, the files are first copied with a temporary extension on the SFTP server, and then I suppose WINSCP will rename them.
The point is that I won't be allowed to rename file on the server.
How can I disable the temporary file name transfert mode in a batch mode ?
I read the manual, FAQ and search in the forum.
Is there anyoption for that ?
Patchi
Patchi
"Disabling temporary file name during transfert"
I will try this option and hope will solve the following error message I get.
winscp> put ARTMAS_24399482_1.txt
ARTMAS_24399482_1.txt | 463 KiB | 2673,2 KiB/s | binary | 100%
Cannot close remote file 'ARTMAS_24399482_1.txt'.
General failure (server should provide error description).
Error code: 4
Error message from server: EBIBrokerSshFile.NullDocument
(A)bort, (R)etry, (S)kip, Ski(p) all: Skip
