Timestamp does not resolve correctly in folder name on FTP server
bogomil
@martin wrote at https://winscp.net/forum/viewtopic.php?t=24053#74224:
open ftp://username:password@ftp.example.com
put C:\local\path\data /remote/path/%TIMESTAMP#yyyy-mm-dd%_data
See
https://winscp.net/eng/docs/guide_automation
https://winscp.net/eng/docs/scripting#timestamp
Many thanks for help – I tested script – but remote folder was not resolved with e.g. /remote/path/2016-12-19_data - remote folder appears as follows:
What can I do? – thank for help in advance ...
Re: Timestamp does not resolve corectly in foldername on ftpserver
Make sure you are using the latest version of WinSCP.
If you are, please attach a full session log file showing the problem (using the latest version of WinSCP).
