"No matching file found"
Uzmark
I have a weird issue.
Using the .NET assembly in a VB.NET application to download files from an sFTP server. It works fine but whenever there is a file with the character [ in the filename, I get "No matching file found" error. It seems that it wont find the file on the remote server.
From the log:
 2017-01-02 14:34:09.860 E[testfile].pdf;-;22546;2016-12-30T08:43:04.000Z;3;"" [0];"" [0];rw-rw----;0
< 2017-01-02 14:34:09.860 Script: No file matching 'E[testfile].pdf' found.
If I remove the [ character in the filename the file downloads fine.
Is there a limitation on having files with the [ character in it?
Uzz
Uzmark
Re: "No matching file found"
Anyone, please?
I tried to use the session.MoveFile command to remotely rename the file, but since the file cant be found (although it is there) when the [ character is in the filename, the command is unsuccesssful.
Kind regards
Uzz
Uzmark
Thank you for pointing in the right direction Martin, I managed to resolve the issue.
Uzz
