Scripting Assistance
WellConnIT
Sydney
I've got two scripting questions.
I've got two folders, Graphics & Swatch ;
I have a remote FTP server that has corresponding folders.
Each Folder has it's own script(to allow the user to upload a single folder rather than both = less time)
Using WinSCP I can successfully connect and upload files ; however:
1. I can't seem to be able to find out how to use the uppercase function of the GUI to change the filenames of all the swatch files to uppercase.
2. Is there a way I can keep the folders up to date without needing to re-transfer files that had already been transferred, like an update function vs a send all??
2a. If there's no function to update only new files, then how would I go about changing the name of the extension only after the file has successfully been uploaded (so that it does not change the name of a file that has failed – currently only uploading *.jpg).
Below is the code I'm using for the graphics:
  /ini=nul ^
  /command ^
    "open ftp://UserName:Password@Server/" ^
    "lcd C:\Users\Andrew\Documents\Graphics" ^
    "cd /Graphics" ^
    "put *.jpg" ^
    "exit"
@echo off
if %WINSCP_RESULT% equ 0 (
  echo Success
) else (
  echo Error
pause
exit /b %WINSCP_RESULT%
Re: Scripting Assistance
Use the FileNameCase raw transfer option:
https://winscp.net/eng/docs/rawtransfersettings
(edited in 2022)
Use the -neweronly switch of the putcommand:
https://winscp.net/eng/docs/scriptcommand_put
Or the synchronize remote command:
https://winscp.net/eng/docs/scriptcommand_synchronize
WellConnIT
Sydney
Thank you very much for your assistance both of those solutions worked perfectly.
I'm now looking for a cmd line tool that I can use to compress images on the fly, so if anyone knows of one that compresses JPG images well that'd be great.
Thanks again.
