Put command, what am I missing
GoBlue2
@echo off
/log="C:\FTPlog\WinSCP.log" /ini=nul ^
/command ^
"option confirm off" ^
"put C:\XXXX\XXX\filename.xlsx /xxx/xx/xxx/upload" ^
"exit" ^
if %WINSCP_RESULT% equ 0 (
echo Success
) else (
echo Error
exit /b %WINSCP_RESULT%
I've removed the connecting info, but if I dont have filename.xlsx in there it works without issues and uploads the files.
I want to upload the specific file with a timestamp then remove the file locally after i am done.
Something is missing, either """ or something not sure.
Please helppp
Re: Put command, what am I missing
You are probably missing a slash at the end of the remote path:
"put C:\XXXX\XXX\filename.xlsx /xxx/xx/xxx/upload/" ^
See https://winscp.net/eng/docs/scriptcommand_put#remarks
If that does not hep, we need a log file.
To delete the local file after upload, add the -delete switch:
https://winscp.net/eng/docs/scriptcommand_put#delete
file is uploading but not adding the time stamp added to it when its uploaded
"put C:\xxxxResponsys\filname%TIMESTAMP#yyyymmdd%.txt /xxx/xxx/xxx/xxx/" ^
what am I missing now?
GoBlue2
Is there a way to add a date to a file that does not currently have a date appended to it?
I want to add todays date to the file before I upload it.
You have to add the timestamp to the target name, not the source name:
"put C:\xxxxResponsys\filename.txt /xxx/xxx/xxx/xxx/*%TIMESTAMP#yyyymmdd%.*" ^
