Invalid access to memory - WinSCP 5.9.4
adriaanh
WinSCP version 5.9.4 on Windows Server 2012 R2 Hyper-V virtual machine
Transfer protocol: SFTP
We do a scripted transfer of 2 files daily, 4 and 5 GB per file.
It works 1 or 2 times per week, the other transfers fail.
They fail with this error or this one: https://winscp.net/forum/viewtopic.php?t=24767
The script:
open sftp://{user}:{password}@{servername}/ -hostkey="ssh-rsa 2048 {hostkey}" -rawsettings SendBuf=0
put -resumesupport=on C:\Backups\{file1} /backup/
put -resumesupport=on C:\Backups\{file2} /backup/
The error (these are just the first few stack traces, it continues until the scheduled task is killed after 12 hours):
Searching for host...
Connecting to host...
Authenticating...
Using username "{user}".
Authenticated.
Starting the session...
Session started.
Active session: [1] {user}@{servername}
C:\Backups\RLP-SQL1\SQL\{file1} |     5133544 KB | 7935.6 KB/s | binary | 100%
C:\Backups\RLP-SQL1\SQL\{file2} |     1010083 KB | 118829.6 KB/s | binary |  26%
expected key exchange reply packet from server
(A)bort, (R)econnect (5 s): Reconnect
Authenticating...
Authenticated.
Session started.
C:\Backups\RLP-SQL1\SQL\{file2} |     1137610 KB | 36782.4 KB/s | binary |  29%
Invalid access to memory.
Please help us improving WinSCP by reporting the error on WinSCP support forum.
(003E10E7)
(00866B5E)
(00868BC6)
(00865980)
(00854593)
(00615DD7)
(00619ABB)
(0062A33B)
(006FDCAC)
(006F8BF6)
(00736CEB)
(00771BF7)
(007737D1)
(0076DB99)
(0075B7B3)
(0075A90A)
(00787619)
(006EEB85)
(006E9803)
(006EAB76)
(00053F97)
(0005A43A)
(000D640A)
(000024A8)
(00864B95)
(00059B8D) ntdll.dll
(00059B55) ntdll.dll
(008671C9)
(008687A3)
(0077066D)
(00771BF7)
(007737D1)
(0076DB99)
(0075B7B3)
(0075A90A)
(00787619)
(006EEB85)
(006E9803)
(006EAB76)
(00053F97)
(0005A43A)
(000D640A)
(000024A8)
(00864B95)
(003E1151)
(00866B5E)
(00868BC6)
(00865980)
(00854593)
(00615DD7)
(0062B9F3)
(0062A284)
(006FDCAC)
(006F8BF6)
(00736CEB)
(00771BF7)
(007737D1)
(0076DB99)
(0075B7B3)
(0075A90A)
(00787619)
(006EEB85)
(006E9803)
(006EAB76)
(00053F97)
(0005A43A)
(000D640A)
(000024A8)
(00864B95)
(008671C9)
(008687A3)
(0077066D)
(00771BF7)
(007737D1)
(0076DB99)
(0075B7B3)
(0075A90A)
(00787619)
(006EEB85)
(006E9803)
(006EAB76)
(00053F97)
(0005A43A)
(000D640A)
(000024A8)
(00864B95)
(003E1151)
(00866B5E)
(00868BC6)
(00865980)
(00854593)
(00615DD7)
(0062B9F3)
(0062A284)
(006FDCAC)
(006F8BF6)
(00736CEB)
(00771BF7)
(007737D1)
(0076DB99)
(0075B7B3)
(0075A90A)
(00787619)
(006EEB85)
(006E9803)
(006EAB76)
(00053F97)
(0005A43A)
(000D640A)
(000024A8)
(00864B95)
(008671C9)
(008687A3)
(0077066D)
(00771BF7)
(007737D1)
(0076DB99)
(0075B7B3)
(0075A90A)
(00787619)
(006EEB85)
(006E9803)
(006EAB76)
(00053F97)
(0005A43A)
(000D640A)
(000024A8)
(00864B95)
(003E1151)
(00866B5E)
(00868BC6)
(00865980)
(00854593)
(00615DD7)
(0062B9F3)
(0062A284)
(006FDCAC)
(006F8BF6)
(00736CEB)
(00771BF7)
(007737D1)
(0076DB99)
(0075B7B3)
(0075A90A)
(00787619)
(006EEB85)
(006E9803)
(006EAB76)
(00053F97)
(0005A43A)
(000D640A)
(000024A8)
(00864B95)
(008671C9)
(008687A3)
(0077066D)
(00771BF7)
(007737D1)
(0076DB99)
(0075B7B3)
(0075A90A)
(00787619)
(006EEB85)
(006E9803)
(006EAB76)
(00053F97)
(0005A43A)
(000D640A)
(000024A8)
(00864B95)
(003E1151)
(00866B5E)
(00868BC6)
(00865980)
(00854593)
(00615DD7)
(0062B9F3)
(0062A284)
(006FDCAC)
(006F8BF6)
(00736CEB)
(00771BF7)
(007737D1)
(0076DB99)
(0075B7B3)
(0075A90A)
(00787619)
(006EEB85)
(006E9803)
(006EAB76)
(00053F97)
(0005A43A)
(000D640A)
(000024A8)
(00864B95)
(008671C9)
(008687A3)
(0077066D)
(00771BF7)
(007737D1)
(0076DB99)
(0075B7B3)
(0075A90A)
(00787619)
(006EEB85)
(006E9803)
(006EAB76)
(00053F97)
(0005A43A)
(000D640A)
(000024A8)
(00864B95)
(003E1151)
(00866B5E)
(00868BC6)
(00865980)
(00854593)
(00615DD7)
(0062B9F3)
(0062A284)
(006FDCAC)
(006F8BF6)
(00736CEB)
(00771BF7)
(007737D1)
(0076DB99)
(0075B7B3)
(0075A90A)
(00787619)
(006EEB85)
(006E9803)
(006EAB76)
(00053F97)
(0005A43A)
(000D640A)
(000024A8)
(00864B95)
(008671C9)
(008687A3)
(0077066D)
(00771BF7)
(007737D1)
(0076DB99)
(0075B7B3)
(0075A90A)
(00787619)
(006EEB85)
(006E9803)
(006EAB76)
(00053F97)
(0005A43A)
(000D640A)
(000024A8)
(00864B95)
adriaanh
Same error
Error looks the same. This time with a logfile.
[code]Searching for host...
Authenticating...
Authenticated.
Session started.
C:\Backups\{file1} | 5141436 KB | 5953.4 KB/s | binary | 100%
C:\Backups\{file2} | 998222 KB | 134201.5 KB/s | binary | 26%
Authenticating...
Authenticated.
Session started.
C:\Backups\{file2} | 1360088 KB | 33174.4 KB/s | binary | 35%
(003E7A80)
(003E7A80)
(003E7BB1)
(0076A5A9)
(0075E4C7)
(0075B77C)
(0075A90A)
(00787619)
(006EEB85)
(006E9803)
(006EAB76)
(00053F97)
(0005A43A)
(000D640A)
(000024A8)
(00864B95)
(003E10E7)
(00866B5E)
(00868BC6)
(00865980)
(00854593)
(00615DD7)
(00619ABB)
(0062A33B)
(006FDCAC)
(006F8BF6)
(00736CEB)
(00771BF7)
(007737D1)
(0076DB99)
(0075B7B3)
(0075A90A)
(00787619)
(006EEB85)
(006E9803)
(006EAB76)
(00053F97)
(0005A43A)
(000D640A)
(000024A8)
(00864B95)
(008671C9)
(008687A3)
(0077066D)
(00771BF7)
(007737D1)
(0076DB99)
(0075B7B3)
(0075A90A)
(00787619)
(006EEB85)
(006E9803)
(006EAB76)
(00053F97)
(0005A43A)
(000D640A)
(000024A8)
(00864B95)
[/code]
  • WinSCP - case 2B - log - forum.txt (153.64 KB, Private file)
Re: Invalid access to memory - WinSCP 5.9.4
adriaanh
Hi Martin,
I had already added a logfile in my second post to the thread:
WinSCP - case 2B - log - forum.txt (153.64 KB) [Download] Private file
Description: (none)
Sorry, I've missed that.
The version of ProFTPD, you are connection to, is pretty old (at least 6 years). Please upgrade the server first.
(WinSCP still should not crash, that's true, but the root cause is some misunderstanding between WinSCP and the server).
adriaanh
Hi Martin,
The company that manages the server has installed a new server with up-to-date software. We don't have the same issues with the new server.
Thanx for your help!
