Kitty Portable with ini file and keyfile does asks for password.
                I have a portable winscp setup and I was using kitty portable alongside it.
Winscp has been setup to log in using a keyfile in the host profile ( no pageant ) and logs in fine.
I just noticed that in this setup Winscp will ignore the host key and kitty requires a password to login.
It does not seem to create the winscp default session either and appears that it will only work if registry keys are in use.
I don't want to use kitty + registry as that sorts of defeats the purpose of a portable solution.
Is there a way I can log into the server using Winscp portable + kitty portable when winscp is set-up to log in in using a keyfile?
