Registry export - import from non-running machine
smrman
Yep, it happened, I made a fresh install of a new Operating System (of course made a full backup of the old C Drive), but forgot to export the WinSCP settings in advance.
Luckily you explained on
https://winscp.net/eng/docs/faq_transfer_config
how to reimport these settings through the ntuser.dat, so I tried.
Somehow, this Key does not contain the actual Server information, after importing the reg no change (not even after restart of the laptop); see attached image
Am I doing something wrong, or is the suggestion outdated ?
smrman
solved through Putty settings
well well, you even offer an import of existing Putty or Filezilla settings, saved my day :)
Had the Putty settings stored correctly, so all up and running again !!
