Automation fails with files with [ character in the name (5.7.7 and 5.9.6 tested)
r4v3n
Stockholm, Sweden
We are transferring files with [ character in the name with WinSCP automation, but keep getting errors about file handles not released and this error:
Details "WinSCP.SessionRemoteException: Mask is invalid near 'c - Copy [7 ).apa'.
Can you try to transfer files with these names?
a - Malmö test [1].txt
b - Göteborg test [2].txt
c - Umeå test [3].txt
Would it be possible to fix this so [ files can be transferred successfully? Also å character seems to have changed to cross character in some logs. It does the transfer though as long as there is no [ character in the name, soNot sure if encoding issue also?
