Webdav script 405 Method Not Allowed
StewieGriffin
When used over GUI everything works fine. When you open an already existing Session in a batch script everything works fine.
But when you generate your session code to do a batch or powershell script the "405 Method not allowed" error is shown.
Here is a working example:
option batch on
open CloudSession
lcd test
cd test
get *.*
close
When i connect to the session via gui and generate a session code it looks like this:
open davs://user:password@cloud.xxxxxx.com/
When connecting with winscp.com:
winscp> open davs://user:password@cloud.xxxxxx.com/
Verbinde mit entferntem Rechner...
Verbindung fehlgeschlagen.
winscp>
Same error on this Powershell code:
# WinSCP .NET assembly laden
Add-Type -Path "C:\Program Files (x86)\WinSCP\WinSCPnet.dll"
# Sitzungsoptionen konfigurieren
    Protocol = [WinSCP.Protocol]::Webdav
    HostName = "cloud.xxxxxx.com"
    PortNumber = 443
    UserName = "user"
    Password = "password"
    WebdavSecure = $True
    TlsHostCertificateFingerprint = "00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00"
Ausnahme beim Aufrufen von "Open" mit 1 Argument(en): "405 Method Not Allowed Verbindung fehlgeschlagen."
Any ideas what could be wrong here?
Hi Martin,
you were absolutely right.
By adding
RootPath = "/remote.php/webdav"
to the Powershell script or adding the root folder to the batch code:
open davs://user:password@cloud.xxxxxx.com/remote.php/webdav
winscp successfully connects to WebDav Service.
Thank you for your quick help :D
supermankelly
Essex
I wish I has found this yesterday. I spent half the day working this out myself. Mine only worked with user password also which is also missing from generated code.
This was post was raised 2 years ago... why is the generated code still broken for WebDAV?
It's not broken.
There's no way WinSCP can know that the root is not accessible with WebDAV.
Grégory Catto
Resolve WebDav 405 Method not allowed problem in WinSCP
In the WinSCP parameters, you can try to set the true TLS/SSL version of the server.
Try TLS 1.1 to 1.2. It can resolve the problem
