Turning off backup copy when overwriting a file using the GUI
sda
When I use the GUI to copy how do I turn off winscp making a backup copy of the file I am overwriting ? It backs up the replaced file by renaming it with a time and date stamp in the name before copying the new file.
Re: Turning off backup copy when overwriting a file using the GUI
So then, isn't it the server itself that does the backup?
sda
Hi Martin, you were right. The server side sftp software was renaming the original file. Its weird that this setting was suddenly enabled.
Simon
